I have had this problem for a while noq where the monobloc tap wont turn all the way on, ie the lever would lift 3/4 of the way up on hot or cold. Eventually it does go up with a clicking feel but sometimes like now, it won't turn the water off, it goes down 3/4 of the way. I have turned the water off (I fitted kitchen myself & putt in some isolators on the end of the tap pigtails) removed the decorative cap & undit the screw thinking it might be the washer, but I am stuck as to how to get the head of the tap off, I cannot see a screw of any kind (I was expecting a grub screw)- basically what now is showing is a square piece of plastic with the thread in the middle (where I removed the screw from) inside the tap head. Am I on the right track with the washer theory? and how do I remove the head of the tap?
thanks in advance
Willy
thanks in advance
Willy
