Hi all,
In my upstairs bathroom I have a Crosswater Modest Monobloc tap which is suitable for low pressure use.
The cold water comes directly from the Cold Water tank mounted 2m above in the loft and the hot water comes directly from the Hot Water Cylinder in the adjacent airing cupboard.
The flow rate of water in hot water mode is good but when the tap is pushed to the cold water only mode the flow rate is perhaps 200mL a minute!
The tap has been installed for circa 5 years and has got progressively worse.
I would appreciate any thoughts on what maybe causing this.
Many thanks
Paul
Many thanks
Paul
