just fitted a fairly standard type of monoblock tap (Wickes Messina £79). On a brand new Franke Ascona sink. The problem is that the tap wobbles, or more correctly ‘nods’ front to back. It’s only slight, but in time limescale (we’re in a very hard water area) is going to form under the front section, limestone cleaner is going to rot the anti-rotation rubber washer/seal and we’ll need to strip it all down to fit a new seal. In addition it is slightly annoying once you know it’s doing it (or is that me getting OCD?).
I thought at first it was flexing of the stainless steel sink, but it is definitely due to the fact that the two screw rods that have to be screwed up tight to hold the tap in place are rather stupidly positioned (as they all seem to be) towards the back end of the tap. Tighten these up tight enough to prevent the tap swivelling, and this ‘nodding’ occurs. Also just noticed there is a very small gap between this seal and the sink top (just enough to easily slide a thin blade between).
Maybe the anti-slip seal/washer is to thick, either way has anyone experienced and solved this problem?
