monoblock tap leak
16 Aug 2007
I've fitted a monoblock tap which now leaks from the swivel joints when I turn the tap. The tap is connected by one long brass nut underneath. Is it simply a matter of getting this nut as tight as I can or do washers need changing. If I need to get inside the tap body, how do I do it, it looks like I need a small allan key just under the handle?
It is the same tap as this one on ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI....akeTrack=true&ssPageName=VIP:watchlink:top:uk
Eh?
You mean at the base of the swivelly spout?
Not connected with bolt underneath . If new, send it back.
sorry for not being clearer. It leaks from the join between the swivelling spout section and the upper tap body. Its not a new tap, I've transferred it from another sink. Any advice would be great.
You need a new O-ring between the spout and the base.
Either a grub screw behind the tap or turn spo9ut 90 degrees and yank. Carefully.
Thats just a typo away from being rude :confused:
why do these questions come in twos and threes? And why don't people look at the "Similar Topics" at the bottom...?
