G'Day gents. Attended a leak last night, turned out to be a flexi to the pump. Its a Monsoon 3bar twin, located the leak to the hot feed from cylnder where the John Guest fitting attaches to the flexible hose.
Question is, I'am going to have to change the hose, to do so I can close the gate valve from cylinder but ther is no other isso points. will there be back flow from the other pipes?, or are they non-return?.
Or do I have to drain and bung cold feed?
TIA,
Craig
TIA,
Craig
