A few weeks before Christmas we suffered a similar problem (breaking glass) with six of our double glazed units fitted in Georgian sash hardwood frames, all cracking within a 3 week period. A single DG unit is fitted in each sash, with the glazing bars glued to the outside with silicone. All installed between 7 & 8 years ago, never had a problem before. Each window has cracked, either inside or outside pane, the crack following the line of the glazing bars. 5 of the six failures happened shortly after painting the inside frame with Satin wood paint - there has to be a connection. The installer claims not to have experienced this before, so is not at present offering replacement under guarantee. Looking on the internet it sounds like a combination of thermal conditions (cold temperature), & deteriorating seals - any thoughts? Dare I risk painting any more windows? Should I specify replacements to be toughened glass?
__________________________
lynda, moderator
BandB, please don't hi jack posts
lynda, moderator
