Hi All,
I have searched for a solution to my problem and haven't had any luck so hopefully someone can assist.
I have a converted garage that I have just moved the kitchen into having previously used it as a study. Obviously, the floor was raised to get all the plumbing in. Having not been at home during the initial conversion some 18 months ago I wasn't fully prepared for what I was to see when the floor was eventually lifted. Under the chipboard floor was a layer of thin MDF closely followed by around 4" of foam. It was a challenge just to get the chipboard up!
Anyway, so having run the plumbing down one side of the room and packed back up with left over foam, the MDF and chipboard went back down. All nice and flat all along the section where the pipework now runs apart from the entrance to the room but I do have a problem. To say I have a squeak is an under statement. We're talking the Adams Family front door here. The normal option would be to add more screws but the floor is not screwed down as there's nothing to screw to! When installed, the fitters had used nails into the foam. Somehow it fixed it very tightly but I don't seem to be having the same response.
The main problem is the chipboard was cut using a circular saw and it's the ends that are rubbing but they're also now uneven. Does anyone have any suggestions to resolve this? I initially thought of cutting out a section of foam where the boards meet and sliding in a cut of 4x2 to screw the chipboard to but I guess even this may cause issues.
Thanks in advance.
Mark
Thanks in advance.
Mark
