Over Xmas we had issues with our heating, which turned out to be a partially blocked pipe.
Throughout the fault finding process the system was flushed numerous times, I then installed fernox f5 for 3 weeks due to other commitments, I also fitted a fernox tf1 omega filter.
Any way replaced blocked pipe, flushed system again, drained and filled 3 times to make sure the F5 was out the system, and then filled with fernox filter fluid + inhibitor.
Heating system was great since, never worked so well in its life, until the other day when I woke to this noise
Also when running the hot water tap you can hear it trickling through boiler.
Can anyone make any suggestions?
I'm thinking it needs a new primary heat exchanger.
I have checked the pressure, it's 1.5bar, I have also bled the system incase it was air, but none is found
I currently pay for homeserve but they are beyond useless, and will likely just tell me I need a power flush again, and don't want all the hassle dealing with them.
