I have to use PIR's in my hall and kitchen as I cannot fit door contacts. The RKP will be in the hall but I will need to enter/exit from the back door in the kitchen or front door in the hall.
How do I do this with PIR's as I also want to protect the kitchen if someone comes through a window?
The only other solution I can see is fit a hybrid alarm and use wireless door contacts which kind of defeats the purpose since the house was wired for an alarm.
The electrician failed to wire for contacts on the two doors, and it's now too late to run wiring.
Still not decided which alarm so the above question is crucial to getting the right panel.
