Could some one tell me if the B&Q Moretti Acqua Thermostatic Shower valve has Flow restrictors fitted ?
Just replaced a gravity fed Mira unit after a complete bathroom refit and the Moretti which is now fitted is rated 0.5 bar minimum operating pressure and is not coping... should have checked this out first but unfortunately being a plumbing muppet this end and i thought/presumed that 0.5 bar was pretty low and all would be well.
if needs be then will look at fitting pump and re-piping the system but looking for an easy fix to increase flow if possible.
