I need to try and match the mortar colour in the attached image. I appreciate it might involve a bit of trial and error, but would anyone be able to suggest a good starting point?
If you can put bit of the mortar in acid it should leave you with a sample of the sand.
When you finish the joints with a metal tool it brings up more of the cement and forms a more weatherproof skin. Over the years this wears away and leaves the sand more exposed so the original colour is different.
Finishing a lime based mortar with the churn brush exposes the sand.
