I had my patio Slabbed a year ago and already weeds are growing in between them. I suspect that I need to re-point them and am asking for advice on the method and mortar mix.
Are your flags laid on sand and cement or just on unbound sand. If its the later then any pointing will not last as the bedding is slightly flexible and the movement cracks the pointing.
If they were laid on mortar then point with 4:1 plastering sand- cement. The wetter you make it (up to a point) the stronger it will be but the more messy, a pointing gun allows a nice wet mix without creating havoc.
If you dont want to use a gun then a semidry mix well compacted and ironed in is the next best bet.
Did you brush the mix in dry originally?
No, the person who laid them used a wet mix which I suspect was to weak.
No, they were laid on a wet mix.
That looks right. By the way, whats a gun?
