I see more ridge tiles from properties less than 30 years old with soft eroded mortar, than I do with pre-1950's properties.
And all of these recent ones have soft mortar which it seems is 'modern' soft building sand only.
You really need a sand which is flexible to cope with some roof flexing (building sand), but with less loam to give weather resistance (sharp sand).
So you need to mix the two. Either 3:2:1 or 2:1:1 building:sharp:cement
If you try and compensate by doing a strong building sand only mix, then it just cracks in no time. And as mentioned, sharp only will mostly end up in the gutter after falling off the trowel
I have seen quite a few verges with what looks like concrete sand in the mix, and this seemed to have excellent weather resistance, but must have been a pain to lay.
And remember to compact and iron the joints well, to give it weather.
resistance.
And don't use fairy or any other additive. It softens the mix and reduces the longetivity of the mortar in this location. OK for walls, but not roofs
I've seen lots of ridges rebed with poorly finished joints. They look OK from the ground or scaffold, but the poor roofers are not happy when I clamber up the roof to check and tell them to re-do the whole lot if not done correctly.
Its even worse for them when I find the ridges have been repointed and not relaid
