I was wondering if anyone could point me in the right direction to work out the amount of sand and cement i need for mortar to build a wall 9m long by 1m high.
I am going to be using concrete blocks (215mmx100mmx440mm) laid flat so the wall will be 215mm wide. I have worked out i will need around 189 blocks using 10mm mortar joins.
Even a rough idea would be very helpfull. I have tried doing a search but could not find anything for blocks laid flat.
Two calculators i found online gave hugely different results also.
thanks
Trevor
thanks
Trevor
