yes you could use bal green star with a mosaic trowlHi all,
Can you use normal waterproof tile adhesive on sheets of mosaic tiles. I m wanting to use mosaics to tile part of a kitchen.
Regards
Andemz
lol i have had no problems with it with small tilesFirst....the only waterproof adhesive is epoxy adhesive the rest are resistant/repellant ....
What type/size of mosaic are are they.....glass/stone...? ....
As for bal ....Green Star.....I would rather use....Blue Tac.... ....fffs..
what are the problems then ?You have either just started tile fixing...or.....are polish ....
Well let's see what type off mosaic it is then.....
Op,can you let us know please!!!!....
Green star.....what a fiver a tub.....!!!....sums it up doesn't it,at that price?..
It's s h I t.....prceramics...
If your going to do it...do it right,with the correct and best materials you can use....ohh and don't forget to rib the walls,...then smooth with the straight edge off your 3mm trowel,patt with your Marshall town grout float and get them flat...panel pins to help with slippage as well....
Everyday is a schoolday......
