That's what I assumed but they are all different. 8.5, 9.5 etc. I was just going to buy any but a friend said it needed to be compatible with boiler. Some are better than others. It will be just a bulk standard electric shower. I'd like it to be a bit more powerful but not a power shower. Thanks
I've already got a shower wired in but it's dead, not worth repairing as too many broken bits in it. So as I'm having to get a new shower was hoping to be pointed in the right direction as to which one if any are better. Thanks
An electric shower has nothing to do with your boiler B. To maximise an electric showers performance, get the largest rated shower that the electrical circuit and your bill will support. Or upgrade the circuit to take a 10Kw.
Please clarify if
(a) you want an electrically-heated shower
(b) you want a shower that uses hot water from the boiler
(c) you're unsure of the difference between (a) and (b) and aren't certain what your old broken shower was
Maybe post a photo of your current broken shower so we can check what it is.
