As part of a whole house replumb, I am getting the copper microbore ripped out, and was considering replacing with point-to-point plastic - i.e. a F+R from a central location out to each room, rather than a traditional series circuit. I believe the plastic materials cost would be cheaper than the time cost of full copper on a normal loop.
This means I could run each rad off a manifold, and could potentially use motorised valve manifolds, making each room a zone.
I have seen motorised manifolds for UFH, but never for rads. Is there any reason they can't be used? I doubt the higher temp (60C) is a problem, but unsure if flow rates could be a problem.
I know the cost of 10+ programmer thermostats is far greater than 10 basic TRV's, but comparing it to an equivalent like Honeywell evoHome, it seems better to have the stat somewhere on the wall and not part of the rad.
