Motorised Valve
12 Dec 2009
Cardiff
I replaced my central heating in August last year. Since then, the motorised valve has been changed three times. Is there a problem with the Installation. The system works perfectly well when the motorised valve is working properly. The lever has broken and no one has been playing around with it.
You can't go much wrong fitting a valve :rolleyes:
If you replace it again use a Honeywell
