We've been replacing a dud isolation valve in our heating system which has resulted in us having to drain the whole system . I was surprised to find though that the motorized two port valve controlling the heating which should have been closed was also letting by slightly.
I've tried manually opening and closing it and it seems to be free running but I did notice that from the open position it turns a lot further one way that it does the other. I then noticed that the valve for the hot water appears to have the motor fitted the other way round. In other words on the hot water valve the manual over ride wheel is on the side furthest from the boiler on the heating valve it's on the side closest to the boiler.
What I'm concerned about is that the heating valve has had it's motor fitted back to front and that is why it isn't closing correctly. Presumably the motor is designed to turn one way to open and the opposite to close. I don't know if you can fit them back to front but it is clear from the fact the two we have are different ways round they can be fitted differently.
