- Joined
- 10 Nov 2007
- Messages
- 162
- Reaction score
- 4
- Country
Hello,
Wooden external doors in wooden frames. Doors are 45 mm thick and have never been fitted with locks. (just cheapo surface mount night latches only)
The stop is 15 mm and the stile is 83 mm wide on the front. The rear is a solid door w/15 mm stop.
I'm after two mortice deadlocks (sash locks preferred unless there's a reason not to?), keyed alike, that'll keep the house insurers happy. (the frame will give way before any lock, though I'd just sling a brick/broken spark plug through the patio doors myself)
These are a temporary measure until such a time as the house is extended/doors are replaced with decent ones. I'll be posting to an acquaintances work address and fitting myself.
Any reason not to use these?
http://www.uk-locks.co.uk/contents/en-uk/d54_locks_keyed_alike.html
http://www.uk-locks.co.uk/contents/en-uk/d45_Mortice_Sashlocks.html
http://www.era-security.com/media/downloads/british-standard-fortress-mortice-lock---1357909802.pdf
Would you order the 'random key' versions and have a local locksmith switch the levers out, or is it best to order keyed-alike from the supplier?
Would you use the "2.5 inch" lock with 44 mm backset, or the "3 inch" lock with 56 mm backset?
Thanks,
Marko
Thanks,
Marko
