I renovated a house earlier this year. It had severe dampness problems due to holes in the roof and little or no guttering.
Ripped up the wooden floor and replaced with a new concrete one with suitable damp proofing.
Also damp coursed right round all walls.
Replastered and tanked all walls.
Much of the visible dampness has now gone but the walls are still showing high levels of dampness when checked with a meter.
Also, low temperatures in the lower reaches of the walls, caused no doubt by dampness.
Mould is forming as a result of this. Not a massive amount but enough to be an issue.
What I do know is that there is old fashioned(1950s??) insulation between the cavity walls which I'm sure is damp.
Is this likely to be the main cause of the dampness?
Is it realistic to pull it out through the outside wall?
Also, is it an idea to remove the rendering around the lower reaches of the outside walls to allow it to breath? I'd have to do that if I was removing the insulation anyway.
