I recently built a new roof for my garage to replace the very old one, but have started to notice mould now the weather has turned,etc.
I`m not sure there is actually anything i can do about this or why its happening, but would appreciate any advice on it.
The roof is made up of timber joists with plywood screwed over them. I then put a breathable membrane on top of this stapled down. Finally, the main steel box profile roofing sheets with butyl tape between all the joins were then screwed through all of this to the joists.
The idea being that any moisture in the garage would pass through the plywood and the membrane, form on the steel sheets and then drip back down on to the membrane and run down the sloped roof and off down a gutter.
I seem to be getting mould appearing though in lines down the roof - presumably looking like where the sheets are touching the membrane and wood.
Is there anything i can do or have i been a numpty and done something wrong?
The garage is very well ventilated at the moment as one of the windows is still missing glass, the side door is a few loose panels and the main double door has large gaps round it where it also needs repairing/replacing.
Here`s a couple of pics -
