1930s Semi
Went into the loft today.
Smelt a bit musty. Some of the rafters have mold on them.
Half the roof is just slate. The other is slate with felt (80's extension)
Most of the nails through the slate/felt had drips of water on. Some of the felt looks a bit wet.
Condensation?
I took a thermometer up with me but only for a few mins as was a bit peed off.
16ish deg and 50-60% humidity. Is the temp high?
I added loft insulation a few months ago. Some original 100 fibreglass. 200mm knauf
I went to the rafters but not touching the slates/felt.
Do I need to pull it back a bit?
Not had any problems in the past 20 years. Got rid of our carboard moving boxes when I did the insulation and all were dry.
More recent work is chimney taken down below roof level. Left open. I have sort of blocked the breast in the lounge but doubt it is air tight.
Condensation?
