Mould on ceiling / walls/ window frames
17 Jul 2011
Yorkshire
Got a pretty bad mould build up on a bedroom ceiling. Black specks/little patches keep appearing. Also, on the wooden window frames and concrete window surrounds. I have single glazed windows which I suspect could be part of the problem.
I've tried using a HG mould spray purchased from B&Q:
http://www.diy.com/nav/rooms/indoor...mescale_removers/HG-Mould-Spray-0-5L-10287856
Also tried the 1/4 bleach and 3/4 water mix as an anti-mould measure
But whatever I use the mould keeps coming back and it's an absolute nightmare to get rid of and then repaint over.
Another thing I've noticed is that the ceiling near the roof feels wetter/colder than the ceiling further away from the window. I'm hoping that I don't have a damp problem.
Does anyone know anything I can do/use to get rid of the mould permanently? And to keep it away for good...
Somebody else may be able to help you with causes and being able to rectify the source of any damp but as far as paint goes zinsser perma white could be an option for you.
You need to check that your insulation is sufficient and that you have adequate air flow in the room. Do you dry laundry on a clothes horse in the room as this can also cause damp.
Could be an idea to top up the insulation above if required and maybe add a pacifier vent to improve the air flow.
Your maybe better off asking in the building section for better info on how to solve the source of the mould growth and possible solutions for it as this will need rectifying before any painting.
When you have cured the source then you will need to wash down with a fungicidal wash then paint with a mould inhibiting paint as this should slow down any future problems. There are a lot of choice when it comes to this kind of paint that will reflect price and finish so shop around.
