Mouldy grout
10 Aug 2017
Kent
What is the best way to remove mould from grout with out degrouting I have tried pens and they are useless if I have to de grout what is the best way of doing it as a grout rake is useless cheers
A substantial amount of cheap thick bleach applied, and left for several hours or overnight.
You can get some good specific grout cleaners which are specific for doing the job. I use the Moldex spray when refurbing some commercial places if they are not re-tiling everywhere and need the existing tiling spruced up. As Flameport says bleach is they key ingredient when cleaning grout but i know that these specialist sprays do contain inhibitors which reduce the risk of mould returning quickly.
I have used toilet duck for years, apply by cloth or sponge, leave overnight, then the following day, reapply toilet duck, leave for only about 3/4 hour, then using a scrubbing brush give the tiles and grout joints a brisk scrubbing, then rinse clean and dry, then I go over the lot again with moldex spray as it contains anti fungal and anti mildew properties tiles and grout should come up looking very good.
Or as suggested by Steve Cheevers, plenty proprietry brands avaiable
I do a lot of regrouting work, and as you say a grout rake is really no good, I use a fein multimaster, but there are plenty similar tools out there, such as the bosch pf 180, that will do the job, just buy decent blades, and the job is done fairly quick, however it can produce a bit mess lol.
