I recently had a kitchen extension done that has a double layer of kingspan insulation on the inside. The other Kingspan is one of those combined insulation and plasterboard ones.
I need to mount a 20kg TV on this. There are two screws, so that should average to 10kg per screw. But I want to play well within safety margins, as I don't want the TV dropping on any children's heads. As the plaster is backing onto insulation, there is no actual cavity. Can I still use a wall anchor for this? My guess is the anchor would shred through the insulation, to grip onto the plasterboard. Is this correct and is it ok?
Also which anchor is best? Is there much of a difference between brands and styles?
http://www.screwfix.com/c/screws-nails-fixings/hollow-wall/cat7280101
Or should I only be considering something that will anchor onto the brick behind the double layer of insulation?
