My Mountfield R28M Ride-on fails to start after Winter . I tried re charging battery many times, it kicks couple of times then fails. Any tips/help..? Thanks
Two comments.....
Make sure the engine gets full choke;
If you think the engine may be flooded, take the spark plug out, dry it if its wet, crank the engine over, replace the plug and try again.
There isn’t a fuel tap, is there?
John
Two comments.....
Make sure the engine gets full choke;>>Snip<<
John
If you crank it over with the Plug out - put the plug back into the cap and make sure the plug body is held against the motor body otherwise it is likely you will need a new coil pack.
I didn't earth the plug on my Mountfield mower (and that is what is cost me to the help of the wife when cutting the grass!).
After 1 day long charging of battery and many shaking, pulling, kicking & pushing ...somehow engine started. Looks so far OK. Tomorrow need to try again to see it still OK.
Good oh!
If the engine runs at full speed and then ticks over without stalling there’s no need to dig deeper at the moment.
Do check the oil level and the tyre pressures!
Happy cutting
John
