help needed I have a Mountfield SP534 lawnmower and it’s stuck on high revs even after I have disconnected the throttle cable I have checked the govener springs there all in place and freely moving help needed thanks
It's probably best to remove the air cleaner for this, but if you can see the metalwork that the throttle cable was connected to - try pushing it away from you. If the linkages are in place, the engine should return to idle.
John
