Hi everyone. I have a 15m run of 28mm copper pipe, most of which will go in the loft. The pipe will be insulated with pipe sleeving, 19mm thickness.
My question is: What is the best way of securing the pipe to the walls and joists. If I use standard 28mm plastic clips I will have to put them on spacers and cut holes in the pipe insulation so it will fit around them.
I am thinking of using the type of clips designed more for plastic drainage pipes as this would save all the cutting and spacing and potential heat loss. But this is such a common task that there must be clips designed for this very purpose. What do you guys use? Kind thanks in advance.
