- Joined
- 3 Jun 2007
- Messages
- 4
- Reaction score
- 0
- Country
I’m looking to fit a pair of concealed 3/4 inch wall valves. The main body of the valve consists of inlet/outlet attached to the unit (no fixings or clamps). The only way I can see to reinforce the valves through tile and aquapanel is to fed the unit through a wood brace and then clamp the inlet and outlet pipes as near I can to the working body of the valve. Any thoughts on how else I could do this would be much appreciated.
A second issue is that the valves will be serving an overflow bath filler. The filler has a 12mm inlet. Can I simply bring the hot and cold supply into the 12mm inlet?
Thanks in advance for any help with this.
