mouting radiator vertical
14 Dec 2011
Ayrshire
can i buy a normal double radiator 500mmx1000mm and mount it vertical that way i would be putting a trv where the bleed hole is thanks,
You can mount it where ever you like.
However, the output is reduced because the fins are not vertical !
Its sensible to fit rads as they are designed!
Tony
