Move Phone Cable
21 Aug 2013
Derbyshire
Hi
The BT line enters my house next to my front door and goes straight into a small rectangular white box with no sockets. This box is about the size of a matchbox.
From this a cable goes under the carpet to my phone socket where my phone is plugged in.
Im having a wooden floor put down and want to move this cable.
is this possible?
do I have to contact Bt
what is the little white box?
The 'little white box' is where the incoming external cable terminates and is joined to internal cable to serve the socket.
Strictly speaking you should get BT to re-run the cable, at a cost, unless you feel particularly competent to DIY. Bear in mind if you do DIY and get it wrong you will probably end up calling out BT which could then cost you anyway.
That must be quite old as there is usually a master socket fitted ...& not on cable under a carpet.
It might be worth asking BT if they would fit an NT5 master for free, but if not it is easy to replace the cable under the carpet with a new one by opening the "match box" and noting which terminals it is connected to.
Do the same with the master socket.
