Hi Great Site And have looked through the site to try and get help moving a radiator 60cm..I Have a combi boiler system and want to move a radiator without touching the valves.
1. There is a drain outlet valve at the rear of the housr,orDo need to drain the whole system as there is 3 other radiators on the same level and 1 radiator up the stairs.
2.Or is there away to just drain the radiator first.
3. I can get under the floorboards ad was wondering if i can cut the pipes and connect with push fit connectors this way keeps the radiator valves intact.
4.The type of radiatopr pipe is 10mm and flexable i think microbore.
5.If this can be done what is the best type of push fit connetor to use.
Many Thanks In Advance..
