Move radiator without draining system
30 Jul 2008
Staffordshire
I'm a DIYer - reasonably competent.
I want to replace a radiator with a heated towel rail, possibly moving position, so valves need to be removed.
I have a sealed CH/HW system.
Can I do this without having to drain the entire heating system, and how?
Erm ..... yes.
If it's a sealed system then shut off all the rads at their valves, drain the rad you want to change. Using that rads valves, release the pressure from the system and the water should then stop.
Worst case is if you have to change the pipework then you may have to drain a little more out of the main pipework but the majority of the water will still be left in the other rads.
Just to bear in mind, that a 'towel rail' is designed just to warm towels, and not to heat a room. As a rule of thumb, a towel warmer will emit about one third of the heat emitted by a single radiator of the same size, and that's before its output is reduced further by covering it in fluffy insulating towels. So unless your room is particularly warm naturally and doesn't need much additional heat, you may find you still need to keep the central heating radiator as well.
Diyer ,asking if they can do it that way......asking for trouble !!
I once advised the brother in law , a not so competent diy' er , to do it without draining down . Took 3 days for the electrics to dry out !!
Never again !!
Absolutely no need to IMO, as long as the other rad valves shut down properly and even then.
Don't forget the inhibitor (y)
As long as none of the trv s pass.if fitted..asking for a shed full of trouble not draining
Never had any issue just draining what's needed, all valves shut and the boiler isolated then never had a problem, of course now that I've said that I'll be extra careful the next time I need to do it in case I've jinxed it :whistle:
I'm not suggesting that draining down isn't a belt and braces approach and removes the risk, I just don't believe it's necessary.
