Hi
I'm following on from this issue a bit (//www.diynot.com/forums/viewtopic.php?t=67667) but thought it needed a new topic really.
I have the issue that I want to put a new WC in the downstairs cloakroom which currently has a low level system with a vertical soil pipe coming up from the ground (requires an S-trap pan) but all the toilets I can find to buy have a P-trap pan. There doesn't seem to be many S-traps made anymore.
I'm looking to install a close coupled system so if I use a pan with a P-trap, as you can see from my pictures, the pan would be located well away from the wall due to the placement of the soil pipe and therefore the cistern would be well away from the wall as well. Currently the distance between the back of the soil pipe and the back wall is 165mm (6' 5") if this helps.
I'm after a cheap toilet (no need for basin) so ebay has been the best place to look but it's full of P-traps.
Can I move the soil pipe back a bit closer to the wall? Is there an easier solution to this? I think an S-trap would mean the pan would be closer to the back wall but as I said these are hard to come by.
Cheers!
Cheers!
