....and just want to check on the safety aspects.
1. I have built a new timber framed wall, 5 inches in front of the existing wall. I have moved the socket from the back wall onto the timber frame of a new wall by adding c12inches of 2.5mm T&E as it wouldn't quite reach to where I wanted it to go. I cut the 2 sets of cables which fed the socket, added the 2 new pieces of cable, connected them with choc blocks, which I have then wrapped in insulation tape. I have a feeling a qualified sparky wouldn't have done it that way, but is it safe? If I were to do it again, what should I have done? The cables will be in the hollow cavity between the old wall and new plasterboard wall and run horizontally from the existing socket which I understand is the safe zone. .
2. I have then run another length of the 2.5mm T&E from this socket to a 13amp fused switch connection unit. To this I have connected my LED downlights (not earthed as double insulated). What about the earth wire? I have connected the earth wire in the T&E to the FCU, but there is no earth in the flex from the downlights, therefore only one earth wire is connected in the fcu. Also, the instructions I got with the light fitting states, if you are connecting to a ring main, use a fcu with a 3amp fuse fitted. I couldn't find a 3amp fused switch unit (do they exist or can you just swap the 13 amp fuse for a 3amp?
