Igorian said:
you obviously didn't see the funny side, i am saying its not our fault he got a cheap BB connection, he is now suffering the consequences
johnad said:
i use tiscali broadband (1mb) so are you saying this is a bad deal to have to pay £50, ?
i have always received a good service from tiscali and after all this will only be a one off payment all i want is the quickest way to get reconnected to my broadband service.
i would say it is a "bad deal"since you have to pay £50 to have your BB connection moved, as has been said bt do it free.
I once met a genuine bt BB engineer, he confirmed what i already thought.
abc company offer BB @ x rate, abc Co do not actually supply BB, they buy it from BT. if the end user has a problem they have to contact abc Co. abc Co then call BT, since that is at least 2 calls that has to be made it can go wrong from there, if a BT customer has a BB problem they can call BT direct, being a direct BT customer takes priority, if the BT BB engineer finds a problem with the line he passes it back to abc Co, if its a BT BB he calls his office and they sort it pdq.
Although in your case it is a BT line, the BT BB eng still has to pass it back to abc Co.
My point is that although it seems cheaper to have abc Co for BB, in the long run, it probably isnt, you have already had to pay £50.
When i moved house (always with BT) because i was an existing customer, they could not provide a line from the local exchange to do what i wanted / already had, so they redireted a line from the town i used to live in to where i am.
now before you start saying that's B.S. I should point out that i only moved from one side of town to the other, but the bit i moved to is not officially covered by the exchange i was on, but by a smaller "local" exchange, but as i said, the local exchange was not yet "modern", so they ran a line from the town exchange (that i was origonaly on) to where i am, now, i even got to choose a new phone number (which was at the time unheard of with BT)
I did all this about 10 years ago.
now thats what i call service
