Movement in concrete lintel causing cracked plaster.
jpq
8 Nov 2004
I have an 1960's built flat which has a concrete lintel running through the entire length of the property. The lintel is mostly concealed under a false ceiling, however in the lounge it sits flush on top of a block wall. The wall and lintel was recently plastered however the lintel seems to move causing the plaster to crack.
It seems pointless just reapplying plaster as the crack will no doubt reappear. Is there a method for stopping this movement? Or a flexible, paintable product to deal with this?
Many thanks
J
There is always a certain degree of deflection in any beam, and if the beam is deflecting too much, then surfaces finishes will crack.
Consider plasterboarding it instead, and then any movement should not show through.
But first be sure that there is no structural issue causing the cracking.
What is this beam/lintel supporting - where is it running, along the external wall or internally?
Thanks for your reply.
The beam supports the flat concrete roof. I think I'll follow this up with the freeholder / managing agent. Might as well get something for my money!
If it's all ok then dry lining sounds like a good idea!
Cheers
J
