Movement in floor insulation boards
13 Nov 2021
I have put down 100mm PIR boards ontop of a new concrete slab, some areas are fine but in others the boards have a lot of movement. Is it better to use sand underneath to level out or is it possible to fix in place with screws/washers? Over top will be a vapour control layer, underfloor heating and screed.
Thanks in advance
When the screed goes down, it won’t move.
what’s the movement though?
Are the gaps not filled or is it a curve in the boards??
Fill the gaps and tape up before VCL and screed.
