Movement joints in garden wall
pgs
8 Sep 2011
Cleveland
I'm planning a garden wall, 1 brick thick (ie two skins), 7 courses high. There'll be a 10m stretch, a curved stretch (of about 5m), then a 15m stretch.
The question is, do I need vertical movement joints? Some sources talk about movement joints for brickwork in general - usually suggesting every 10-12m or so - but I'm wondering if the size or shape of my wall has an impact? There are plenty of garden walls in my neighbourhood of similar dimensions, but I don't see expansion joints in a single one (and they've been up for years without problems). Is that because it's overkill on a small garden wall, or because of ignorant brickies? Obviously I'd prefer not to have expansion joints if I don't need them as they'll spoil the look of my stretcher bond.
If the walls you have seen are older, they may have been built with lime mortar. This is more flexible than modern cement mortar and accomodates movement better.
Having said that, as long as your mortar is not too cement-rich, and the bricks are not fresh from the kiln, you should be OK.
