Hi Guys.
As some of you may have seen, i live in a flat that is all electric.
In the kitchen and bathroom there are wall mounted electric fan heaters.
I think both are rated at 2kw each.
On the Fuse box there is a separate fuse for each heater.
Each heater also has a wall switch.
Kitchen:
I have decided to move some appliances around in the kitchen, including moving the washing machine to where an under counter fridge was, and cutting the work top and putting a full sized fridge where the washing machine once lived.
Unfortunately this means the Kitchens wall mounted fan heater will be directly in line with the fridge freezer.
I would like to move this to an empty wall in the middle of the kitchen.
Can i do this my self?
Either by extending the electric supply (the heater has its own wall switch)
to the new location, or disconnecting the wire for the old location and running a new one to the RCD
Bathroom:
Also can i do the same with the bathroom wall heater which is mounted directly above the basin. I want to mount a bathroom cabinet in that location.
Kitchen:
Bathroom:
