Hi all,
I've house with one large bedroom at the front and two small bedrooms and a bathroom at the back. However the front and back are about the same size in total, so the back bedrooms were rather cramped.
I have a plan to move the smallest bedroom into the front, to even things up a bit - it was almost unusably small. I have begun by removing it from the back (knocking the two small beds into one), and intend to add a partition in the front in order to reinstate it there. i'm not altering the bathroom
I'll presumably have to get building approval for making a new window opening, but happily i shouldn't need to alter any electrics. However i'm wondering if:
(1) I should have got approval for removing the stud partition (I thought not because it wasn't structural or making access, ventelation etc worse, but now i'm beginning to wonder).
(2) if I need it for partitioning the front bedroom into two,
(3) do minimum door sizes apply upstairs in dwellings, or is it just the principle and/or entrance storey?
I've tried to get into the building regs documents, but am a bit confused: on the one hand it seems partitioning a room may need approval, but on the other when i've finished i will not have either fewer or more rooms than when i started (and what is bedroom space now will be bedroom space then, just re-arranged) so it seems it may not to count as a material alteration or possibly not change of use.
Advice would be much appreciated!
Cheers
Kev
Cheers
Kev
