Moving a central heating radiator
8 Aug 2006
Aberdeenshire
I have a gravity fed system with expansion tank and want to move a radiator to the other side of the room. Has anyone used a kit with plugs to seal the feed and expansion pipes so you dont have to drain the system down completely yo connect up the new rad.
Yes, they are bungs...attach one to vent (pipe that hangs over small tank)& bung the tank inside to prevent water exiting the small tank.... they are not magic.......you will have to pipe up your new rads so bungs probably won`t help much..they do not completley stop water..they slow it down to a stop nearly...
