Dear all
Been looking to move an upstairs radiator to the left 2m.
I don't really want to go through having to drain the whole system and rebalance/bleed the whole lot again, so was wondering if it would be possible to block the header tank outlet in the loft to stop water re-entering the system, turn off all the upstairs rads and then remove the rad I want to without a major disaster
In theory, I keep thinking it would be possible, as the only supply the rad in question would get would be from the other upstairs rads and the header tank.
I have removed the rad and left the valves in situ, so I can test to check the flow has stopped before I get the pipe cutters out!!
Am I being too simplistic in my thinking?
Thanks all
Chris
Thanks all
Chris
