l have just removed a bathroom wall opening it up to be in the same room as the toilet which was on the other side of the wall.
On either side of the wall was radiators which l took of leaving the pipes and valves in place, a smaller radiator one was in the toilet so now l just want to put the larger radiator on the other side of the toilet wall...
So can l blank off under the boards one of the radiators pipes and run underneath the boards in the toilet to the other wall pipes for one radiator..it only needs to go across the width of the toilet about 2 foot..
If l can what would be best to use to blank off one of the radiators, e.g push fit, compression fit etc and the same for moving the pipes for the radiator l'm putting on the wall.
l have a combi boiler system so can someone tell me what l will need to do before and after moving the pipes for the radiator.. Thanks
