- Joined
- 24 Feb 2010
- Messages
- 9
- Reaction score
- 0
- Country
HI, I have a house with an attached granny annexe
both have separate overhead supplies
the meter boxex are on the annexe outside wall
Now i have built a new house next to the annexe ( 3 ft away) but the meter box on the new house will be approx 30 -35 mtrs as it is the other side of the building
the electric company want 6500 to run a cable from the pole in the road (50 mtrs) to the new house meterbox with me doing all the groundwork!!
I wanted to move the supply to the annexe to the new house and then feed the annexe (which is only 3 rooms) from the main house supply
but the supplier wont do that and insists on installing a new supply underground
therefore what i would like to do (i currently have a temp 80A cable supply running from the annexe to the new house, is to run a 100A cable from the annexe to the new house by pinning to the wall of the new house
this will be a run of around 40 mtrs. to the meter box on the new house and i propose to run the cable through the meter box to the consumer unit so that at a later date if the power company gets more reasonable the cable can then be cut and a meter installed .
In the meantime there is no problem (for me) in having the meter box for the new house on the old annexe wall
given the 40mtr run what power/voltage drop is likely and what size cable is recommended .
i can either run from the consumer side of the meter or remove the meter feed from the annexe consumer unit and join the cables inside the loft of the annexe then run to the new house
