Moving a toilet
14 Aug 2004
I want to fit a new bathroom suite & in doing so, move the wc along the wall by about 12-24" & move the basin on to another wall.
I'm Ok with the basin but is moving the wc a DIY job when the floor is concrete?
It will mean you will have to extend the soil pipe with the use of elbows and of course 110 mm pipe.
You will however have this on show but is quite straightforward to do.
Suggest you visit your local plumbers merchants who will advise you as to what fittings will be needed. :)
Great thanks!
I assume that the extended pipe will come out of the original, along so that it's inline with the pan & into the pan?
We don't have a lot to go on. Vertical soil pipe, horizontal, into the wall, floor - imagine we just arrived from Mars...!
OK!
The soil pipe comes up out of the floor, so there will be a female mating piece with a 90° bend to bring the pipe horizontal, followed by a stright piece to bring it to the location of the new pan then another bend to enter the new pan (not purchased yet so fitting unknown).
how's that???
When bedding the pan onto the concrete floor my advice is not to use a sand/cement mix. I've seen a lot of pans cracked because of the stresses set up. I use finish plaster, but I expect others will post on their preferred bedding method.
what about tiling under the pan & fixing the pan to the tiles?
Yes tile first. or it looks awful! I've never used pies of anything like mortar to fix a pan, I just use proper bolts designed for the purpose - which may or may not come with it.
The tiles need 100% fixative bed under them , and to be dead level and flat. I'd drill oversize holes in the tiles cos you aren't trying to get the bolts gripping those. (Sorry - its easy when you have diamond drills of all sizes). If you don't fancy doing bolts up tight, or if you don't want to use them at all, silicone will hold the pan in place.
I use posh bolts (they fill the holes anyway!) but not do them toooo tight, and 3 - 4 small dabs of silicone which are placed so you can slit through them if its necessary to remove the pan later.
Even if you use bolts or screws, you still need a gasket or silicone as well. You don't want any operational inaccuracies seeping underneath it eh?
Quite!
We had that on holiday, the person upstairs flushed & our bathroom filled with water!
er, that isn't what he means- operation on the person side... especially small boys...
OK! I get it now. I did post that at 9am sunday so I wasn't quite with it!
