moving a toilet
6 Dec 2005
East Lothian
Hi
having just moved house we find that the 2 toilets are too close to the wall. they need moving over about 6 inchs. Without stripping the panelling down yet I think I can see a problem in that the 4" waste pipe coming out of the rear of the bowl must go into a soil pipe and this will be fixed position. If we move the toilet sideways is there a flexible coupling that I can get to reconnect the soil pipe ?
Also can anyone point me to good instructions for doing this task as i've never moved/fitted a toilet before ? :?:
There is a flexible soil pipe available, though I would be worried about it encouraging blockages.
Does your soil pipe rise up through the floor, or come in from the back wall or the side wall?
Am I right in thinking you want to move the pan sideways (from the perspective of someone sitting on it) because his knee is against the side wall?
the soil pipe comes in horizontally form a tiled box section to which the toilet is fixed, im assuming that in the box section it joins to a right angled pipe and goes downwards.
yes i dowant to move it sideways a bit away from the wall as you suggest
...Does your soil pipe come in from the back wall or the side wall?
If it's coming in from the side you can easily fit a slightly longer/shorter piece, but if it comes in from the back, could be a bit tricky as i don't suppose you'll have room to change direction.
