- Joined
- 6 Aug 2019
- Messages
- 56
- Reaction score
- 1
- Country
Evening All.
As part of an extension (self) build, my boiler, which is oil fired, needs moving.
Am I able to do this myself?
It is a standard worcester danesmoor oil boiler (non condensing, year 2000) The piping is very simple, and not being moved very far, so I could easily do that myself. The oil supply pipe would then need to be rerouted - again very easy.
The bigger job is the flue, which currently goes up the chimney. A new flue will be needed, which goes up the side of the house. As it's not a condensing boiler, again I think that makes things easier as just a bog standard new flue can be used.
Is this doable, or is a professional essential? Will building control sign off on my extension if I do it myself or does it need certifying?
I know someone will suggest getting a new boiler as this is an old one, but I've read that these older ones last forever and are very simple so that is an expense I could do without.
Many thanks.
Many thanks.
