Moving consumer unit - best practice?
7 Jul 2006
Sussex
I have to move a consumer unit about 5m from existing position. Most of the circuits will be extended from where they are to the new position. I would normally use a junction box with appropriate terminal blocks to connect the cables.
Any suggestions on alternative methods gratefully received.
Hello.
Are you moving the new cosumer unit away from the incoming supply point as I believe local authorities only allow meter tails to be a certain length? ( 3mtrs here.).
Is there anyway you could run some trunking for the cabling and crimp and sleeve them in it ? Any screwed connections ( so to speak !) must be accessible for inspection etc.
Hope this is of some help.
Nothing to do with the Local Authority.
